Большой архив программ для работы с иммобилайзером
Большой архив программ для работы с иммобилайзерами. Так же в архиве присутствуют различные справочные материалы.
Список программ:
1. AE Tool FULL
2. B-Chip
3. BMW Editor 3.2.0
4. Carsoftware 5.2
5. Dash ECU Teacher
6. Data Explorer Manager Tools
7. ECU Calc 2
8. Ford Connect
9. Ford ECU Licensed
10. Ford Fiesta SIM210 v1.1
11. IMMO 3
12. IMMO Decoding 3.2
13. IMMO Killer 1.10
14. IMMO Nissan
15. IMMO SCP
16. Komatsu Time 1.2
17. ME 17.9.7 VAZ Remover
18. Opel Pin Repair
19. Opel VIN decoder
20. PATS
21. Peugeot Code
22. PSA Dump2Pin
23. PSA ECU PIN
24. Renault PIN Extractor 2
25. Renault PIN-Code On Key Number
26. TM100 1.23
27. Toyota 4 DKeyTool 1.2
28. VAG EDC16 IMMO Bypass
29. VAG Eepromer 1.18p
30. Visteon 2.3
31. Volvo ECU 2.3
32. Volvo Synchro 1.4
  • иммо офф.txt
    54 байт · Просмотры: 25
Софт: пароль: auto-vip.org
Toyota 4D Key Tool v1.2
Toyota 2005-2010 immobilizer repair and synchronization with motor ECU utility
Volvo S60, S80, V70, XC70, XC90 2000-2004 CEM repair and synchronization with motor ECU utility. V1.4
Dash-EcuTeacher V1.8
Dash - ECU Teacher With this product you can teach almost all dashboard's from VW, Skoda, Seat with micronas or NEC inside.
Volvo S40 2004-2009, V50 2004-2009, C30 CEM repair and synchronization with SID803 motor ECU utillity.
Komatsu Time V1.2
This program will help you to exchange damaged instrument cluster for Komatsu industrial equipment
Ford Fiesta 2006-2009 DASH 1K78X - ECU (SIM210) Synchronization utility v1.1
Ford Fiesta 2006-2009 DASH 1K78X - ECU(SIM210) Synchro Ford Fiesta 2006+ transponder key programming and used (second-hand) SIM210 ECU synchronization utility
Visteon ST95320 v2.3
With this software you can change PIN code, Component Security, repair error message on the dashboard
Visteon ST95160 V2.4
Ford Transit Connect 2005-2010 immobilizer system repair, transponder key programming and used (second-hand) SID206 ECU synchronization utillity. V1.1
Visteon ST95160 V2.3
Ford Mondeo 2008+, Galaxy 2008+, S-max 2008+ transponder key programming and used (second-hand) SID206 ECU synchronization utility.
  • прога.txt
    43 байт · Просмотры: 15
Ford All in One32 пароль: auto-vip.org
  • прога.txt
maksat
сАЛАМ ВСЕМ
Добавлено через 50 секунд
НЕ ПОЛУЧАЕТСЯ УСТАНОВИТЬ ИММО ДЕК 3
ПОМОГИТЕ
ARGOUS
you have software for 4hv ecu?
ARGOUS
dont can remove immo
ARGOUS
