DPF DTC EGR Lambda Remover Список проверенных авто
DPF DTS EGR Lambda Remover Список проверенных авто
2017 version work OK:
1. Opel Astra J 1.7 CDTI 81kW DENSO R/W KTAG, Temperature and Differential sensor must be diconnected - OK
2. Ford kuga 2000 136 siemens sid dpf egr off ok
3. Mercedes Sprinter 2009 edc17cp10 dpf egr off - ok (sensors connected, ECU have egr fault but no limp and safe mode)
4. Alfa mito 1.6 MJD 120cv_edc16c39 EGR ok.
5. I did 3 Fiat Ducato 2.3 MJ8., 2 of them got DPF and EGR off, DTC gone, car runing ok. One had the DPF light on, 0 dtc but the light was still on and the message on the display "keep vehicle running". The score is 2-1 for the MJ8 Ecu, keep you updated.
6. Sid 803 for mpc dtc files Egr ok
7. fiat edc16c39 egr is ok dpf not work all switch
8. DPF-EGR golf 5 1.9 105 cv edc16 tutto ok
9. VW Touareg v10 5.0ccm3 313ps (master and slave ecu ) work ok.......only BDM File.....obd not work
10. Sid803 DPF OFF ok. I must say that I read the file with kess and use the program to split it into mps and fls. The 400kb mps file worked with dpf off.
11. sid 803a peugeot dpf egr is ok and delete one dtc (Sid803 not that ok. Got a dtc on after 2 days.)
12. range rover sport 2.7 Sid204 2006 EGR OFF Disconnected connector ... OK
13. Dpf_Egr_Ford Focus Edc16c34 Remember to disconnect the liquid control unit connector
14. Ford C-Max read/write CMD1255 EDC16CP34 DPFoff = OK
15. Nissan Qashqai read/write Galletto v54, EDC16CP33 DPFoff = OK
16. Opel Vivaro read/write MPPS v18, EDC15 EGRoff = OK
17. Opel Vivaro read/write CMD1255, EDC16CP36 DPFoff = OK
18. Opel Zafira B read/write CMD1255, EDC16C39 DPFoff = OK
19. Opel Zafira B read/write CMD1255, EDC16C9 DPFoff = OK
20. Opel Astra G, Zafira A, read/write MPPS v18, PSG16, EGRoff = OK
21. Opel Meriva A 1,7cdti DENSO DEC (read/write IOTERMINAL), DPFoff = OK
22. Toyota Denso 89661-42C00 DPF OK
23. Fiat Ducato MJD 8F3 DPF EGR ok
24. golf 1.6 PCR 2.1 EGR and DPF Ok
25. Opel Astra H, Z13DTH, (R/W CMD1255 MJD 603), EGRoff = OK
26. Opel Combo C, Z13DT, (R/W cmd1255), EGRoff = OK
27. Astra h 2007 EDC16c39 1.9cdti read by kess obd dpf off ok
28. Ford focus 2008 1.6tdci read by kess obd dpf off ok
29. alfa 147 1.9 120cv Edc16c39 EGR OK.
30. Astra h 2006 EDC16c9 1.9cdti read by ktag bdm dpf+egr off ok
31. alfa romeo 159 1.9 150 cv edc16c39 solution 2 detached connector EGR OFF OK
32. alfa mito 1.6 MJD 120cv disconnected connector solution EGR does not work Soluzione generic ok!
33. bmw x3 2.0 150cv edc16c35 EGR_off ooook
34. Dpf_Egr ok_ Classe C 220 2.0 150cv edc1632
35. FORD_KUGA_2.0_163KS_2011_ECU: AV41-14C204-DM = DCM3.5 (R/W by KESS via OBD2) removed DPF, everything is OK !!! (cuby)
36. FORD_C-MAX_2.0_2003_8M51-12A650-HC_SID803 (R/W by FGv54 via OBD2 selected CAN) DPF removed, everything is OK (cuby)
37. Astra-H_1.9CDTI_2005_Z19DTH_EDC16C9 (R/W by mppsv18 via OBD2 selected CAN) DPF+EGR removed like generic EDC16C9 (EGR connector must be connected, if disconnect comes P0400), OK, (cuby)
38. Hot Start Passat 3C PPD 1.1 OK
39. DPF off Passat 3C PPD 1.2 OK
40. Hot Start Golf V ok
41. DPF - BMW E60 2.5D, 3.0D, EDC16C31 - ok. No DTC.
42. Lambda CAT - BMW X6 3.5i MSD80 - ok.
43. DPF off VW Golf 1.6TDI ECU PCR 2.1 - OK
44. Egr edc17 Vw golf6 ok
45 Audi A4 2.0 diesel 2008year PPD1.3 not OK after remove DPF car starting but RPM is 1600 IDLE(DPF REMOVER all OK)
46. Opel EDC16C39 DPF_OK
47. Captiva 2.2 DCM3.7 work perfect
48. sharan 2.0cr edc17c46 adblue OK
49. vectra edc16c9 dpf ok
50. 307 1.6 edc16c34 fap off ok
51. FORD transit visteon DCU-102 egr okk
52. Passat-Octavia 2.0 TDI PD EDC16U34 EGR=OK (cuby)
53. MITSUBISHI L200 ECU DENSO 4D56 DPF OFF OK
54. MERCDEZ SPRINTER DELPHI DCM3.5 TYPE 1 EGR DPF OFF OK
55. NISSAN NAVARA DENSO DPF OFF OK
56. HYUNDAI BOSH EDC17C08 DPF OFF OK
57. ford focus edc16c34 - DPF/EGR off ->> OK
58. bmw e90 edc16c35 - DPF/EGR off ->> OK
59. ford fiesta sid804 - DPF/EGR off ->> OK
60. vw passat 2.0 siemens ppd 1.2 EGR_OFF OK
61. MB e320 edc16c2 EGR ok
62. audi a4 2011 edc17cp20 dpf ok
63. Ford Kuga SID 206 dpf ok :)
64. Clio 2 1.5 65cc delphi Egr off ok.
65. chevrolet captiva edc16c39_ dpf ok
66. Ford S-Max 2007 SID 206 EGR off= OK
67. Opel Vectra 1,9DTi 16c39 dpf off= (OK)
68. WV Transporter 2006 2,5 96kW EDC16U34 DPF Generic Switch (OK)
69. renault edc16C03/9 DPF OK
70. mazda5 2006 2,0 81kW DENSO dpf (OK)
71. I test old version on 635d with edc16cp35 and works Very good with dtc off.
72. Worked for me. Made a mazda 3 with ecu 0281011995 and no problem at all.
73. mazda 3 2007 1.6d edc16c34 dpf solution -OK
74. Audi A4 EDC17CP14 DPF Off
75. Audi Q7 EDC16CP34 DPF Off
76. VW Touareg EDC16CP34 V6 DPF Off
76. Renault Scenic EDC16C3 V1 DPF Off (How to know the version you need ? )
77. BMW 320D EDC16C35 DPF Off
78. BMW EDC16C35 DPF EGR OK
79. PEUGEOT DELPHI DCM3.5 DPF OK
80. AUDI A1 SIMOS PCR 2.1 EGR DPF OK
81. Audi a4 2.0 tdi edc16u31 egr off ok Tup
82. peugeot 308 edc16c34 dpf ok
83. volvo s60 edc16c34 version switch ok
84. Tested On Denso Mitsubishi DPF made more than 10 cars and no problem with Both Processor 7058 and 7059 …
85. Alfa 159 edc16c39 egr OK
86. Opel Zafira edc16c39 dpf OK
87. MB E320 w211 EDC16C2 DPF Type 1 don’t work Type 2 DPF OFF ok.
88. Opel vivaro 1.9dci EDC15C2 Egr off ok with disconnected egr plug.
89. BMW 120d 2009 edc17cp02 egr off (OK)
90. Peugeot P406 edc15c2 egr off (OK)
91. Peugeot P407 edc16c34 egr off (OK)
92. Golf 6 PCR 2.1 egr off (OK)
93. Passat B6 EDC17CP20 dpf off (OK)
94. Citroen c4 1.6 hdi edc16c34 egr off (wrong solution)must use Peugeot (Solution 2)
95. Ford Galaxy 2.0 tdci SID206 egr off (OK)
96. Clio 1.5dci egr off (OK)
97. audi A3 with pcr 2.1 for dpf and worked perfectly.
98. suzuki 1.9 dpf ok
99. peugeot edc17c10 dpf ok
100. Hyundai Santa Fe 2008 edc16c39 EGR OFF P0489 EGR Disconnect, delete ok DPF OFF error P2002 P0473?—?delete OK
101. I tested on edc16c31 type 2 dpf off. work fine.
102. I never have problem with mercedes edc16 ecus for dpf off only egr solution is not good.
103. Ford Transit 2.2TDCI DCU101, EGR off = Ok
104. Mazda 6, engine code RF, model year 2005: DPF OFF ok, seems all faults codes deleted by the software,
105. Flap off mercedes c220 e mercedes classe B=ok
106. Peugeot 407 EDC16c34 FAP off……OK
107. mitsubishi denso dpf off ok
108. ford KUGA delphi 3,5 dpf off. GOOD TESTED
109. SUZUKI EDC16C3 1.9 DDIS DPF OFF OK
110. i have tested on laguna 2 1.9 dci edc16c3–9.21 type 1 for dpf and egr off. Ok for the moment after 500kms…
111. VW Pasat 2.0tdi 170hp.siemens pdd1.2 dpf-OK , for me audi A4 PPD 1.2 dpf don’t work . how you can do that…just remove dpf sensor and drive car for few Km
112. Citroen Jumpy 2.0hdi delphi dcm3.5 dpf off …ok
113. ford connect 2013 sid206 egr dpf off ok
114. laguna 2 1.9 dci edc16c3–9.21 type 1 for dpf and egr off
115. SUZUKI EDC16C3 1.9 DDIS DPF OFF OK
116. ford KUGA delphi 3,5 dpf off
117. mitsubishi denso dpf off ok
118. Peugeot 407 EDC16c34 FAP off……OK
119. Flap off mercedes c220 e mercedes classe B=ok
120. Volkswagen Passat cc edc17c46…egr off OK
121. Ford Transit 2.2TDCI DCU101, EGR off = Ok
122. EGR and DPF on fiat = Good
123. EGR and DPF on hyundai = Good
124. Hyundai Tucson 2.0 CRDI 4WD 2006 DPF OFF
125. VOLVO S60 & XC90 EDC16 DPF OFF WORK OK
126. VW Crafter EDC16CP34–4 DPF and EGR off,works OK
127. Focus 1.6 tdci EDC16C34 EGR OFF ok with DTC table patch.
128. Ford Mondeo, year 2008, Siemens SID206, EGR OFF works ok
129. Egr golf 5 edc16u1 1.9l 105cv bkc ok.
130. Audi A5 2.7tdi edc17cp14 dpf OK.
131. Citroen Xsara Picasso, year 2007, engine 9HZ, EDC16C34 egr off ok
132. BMW 320d e90 2006r 120kw EDC16c31–35 type 2 solution dpf off -ok
133. Clio 1.5 dci my2007 Delphi DDCR EGR off OK
134. Subaru Legacy Denso DS 2.0TD 150hp DPF OFF OK
135. Subaru Impreza Denso DS 2.0TD 150hp DPF OFF KO Engine run only 500rpm No error in diag
136. megane 2 edc16c3 with 1mega file EGR off 100%
137. VW Golf 6 1.6 PCR 2.1 DPF ok.
138. Audi edc17cp14 dpf off ok
139. Egr off in edc16c9 opel ok
140. DPF OFF and EGR OFF for PCR2.1 work good but have do separate !!!
141. DPF OFF for Audi a6 3.0tdi 224hp work perfect and can unplug all sensors
142. DPF OFF for Audi q7 3.0tdi 233hp work perfect and can unplug all sensors
143. Opel Zafira 1.9CDTI 120hp 2008year BOSCH EDC16C39-DPF OFF=OK
144. Vw golf 6 2.0tdi 103kw 2010year BOSCH edc17c46-DPF OK
145. Seat Ibiza 1.6CR TDI 105hp 2012year SIMOS PCR 2.1=>EGR OFF=OK
146. Mercedes w221 s-class 320cdi v6 235hp 2008year EDC16CP36=>DPF OFF=OK
147. Mercedes E320 w211 EDC16C2 DPF Type 2, DPF OFF (OK)
148. Work great with FLAPS OFF for Mercedes-Benz CLS 320CDI V6 224hp 2007year EDC16CP31
149. Opel Astra H EDC16C9 1.9CDTI 150hp 2006year for FLAPS OFF and EGR OFF
150. opel meriva a z13dtj dpf off works good.
151. opel corsa d z13dtj dpf off works good.
152. Works good for EGR OFF of BMW e90 320D 163hp 2006year EDC16C35
153. Mercedes W164 EDC16CP31 2MB flash, EGR_OFF_DTC 2527 2511 2355 OFF, Works OK
154. BMW X5 3.0 year 2010 edc16c35 dpf off ok
155. Megane 3 2011 Delphi DCM 3.4 DPF EGR - OK
156. dpf off mazda3 1L6 edc 16c34 110 CV ....OK
157. Audi A4 2011 edc17cp20 flap off OK
158. vw Golf 6 edc17c46 Dpf and Egr ok ;)
159. Renault Megane 1.9 dci edc16c36 130hp egr off OK
160. A4_2.0_TDI_140HP_2005_EDC16U31_03G906016GN_383292_ EGR remover 2017 edited like Type 1 _R/W by FGv54 via OBD2_EGR unplugged, no DTC, everythig's fine
161. astra H denso dpf ok
162. ford focus 1.6 edc16 dpf ok
163. all opel mareli 1.3 cdti egr and dpf ok
164. Mondeo 2007 SID 206 dpf OK
165. Peugeot Boxer 2.2 HDI Visteon DCU-102 egr off OK
166. Opel Zafira A 2001 year, Y20DTH, R/w 29f200bb with Minipro = EGRoff = OK.
167. VW Krafter 2007 year, 2.5 tdci 66kw, eng. BJJ, EDC16U1, R/W CMD1255 = EGR/DPF off = OK
168. Saab 9.3 1900tid EDC16C39 egr off OK but you must remove dtc and unplug connector.
169. Audi A6 2400 v6 ME 7.1 lambda remove OK
170. Opel astra 1.9cdti z19dth edc16c9 egr and dpf off work tested with my car.
171. Audi A3 EDC17c46 EGR OFF ok
172. Transit connect SID206 DPF OFF ok
173. Mazda_2.0_2006_RF_T_RF7KU_Denso_140HP_Kess R/W via OBD2_DPF_OFF_OK !!! not dosconnected plugs. Before of programming, I have made reset DPF (cuby)
174. hyundai santa Fe 2.2CRDI EDC16c39 - looks ok,work ok
175. Jetta 1.6 tdi 2011 pcr2.1 egr dpf. Ok
176. BMW 530d EDC16cp35, 2006, 173kw/ DPF off= ok
177. Renault megan 2010 1.5dci sid305 read bdm by Ktag dpf off ok.
178. nissan_XTAIL 2.0 edc16cp33 dpf off soution 2,2 deys car ok
179. 207 1.4hdi edc17c10 dpf ok
180. C4 1.6hdi edc16c34 dtc off ok
181. Audi Q5 tdi Flap off ok
182. Audi q8 tdi flap off ok
183. Altea tdi edc16c34 hot start ok
184. 147 jtdm edc16c39 immo off ok
185. Clio 1.5 dci ddcr egr off ok
186. audi a3 edc16u1 egr-not ok,hotstart_ok,flaps-ok
187. audi a6 2.7 edc16cp34 dpf off-ok ,3 sensors must be disconected
188. Ford C-MAX 1.6 TDCI 2005 edc16c34 read with Ktag : EGR Off = OK
189. Volvo V70 2.4 D5 edc16c31 DPF off OK
190. Ford mondeo mk3 2.0tdci delphi mpc555 dpf off ok, i made like dcm3.2 micro solution , r/w obd by kess
191. GOLF 6 EDC17CP14 03L906022M DPF+EGR OK
192. Opel vectra c 2,2 DTI(PSG16) egr off - ok
193. Mazda5/2007/105kw/ DPF off= OK
194. Peugeot Partner/2011/82kw/Sid807/ DPF off=OK. Must do Citroen Sid807 solution.
195. Peugeot 307 edc15c2 dpf off ok
196. Dacia logan 2014 1.5dci edc17c42 read-write kess by obd dpf off ok!!!!
197. opel corsa d 2008 z13dtj marelli read-write obd by kess dpf off ok!!!
198. chrysler 300c 30td edc16cp31 dpf off no problem
199. Ford Transit Connect 2009/1,8/110hp/81kw/Sid206 EGR off= OK.
200. Toyota Corolla Verso Denso_ 2.0D4D-CAT 129kw 2008m 76F0038GD 89663-0F097 dpf off-OK
201. VW Passat 2007/2,0/125kw/BMR/PPD1 DPF off=OK.
202. Peugeot_Boxer_2.2HDI_DCU102_2010y_R/W FGv54 on the bench_EGR_off_remover_visteon_not disconnected_OK_(cuby)
203. MB (w212) E250 CDI Blue, R/W Kess V2 (prot 350, DELPHI CRD 3.1) DPF-OFF = OK, after the upload got check light, DPF was reset with Xentry and after seems all ok!!!!
204. Toyota RAV4 2.2 D-4D, R/W Ktag, DENSO 175822-773, DPF-OFF = OK
205. Bmw EDC17CP02/06 motor N47 DPF OFF work ok
206. Nissan Xtrail EDC16CP33 2008/110KW DPF off=OK (type2)
207. santa fe edc16c39 dpf off ok
208. Ford focus 1.6TDCI 2009 year(DPF with lambda senosr) EDC16u34 DPF OFF with solution "9M51" -worked ok.Ecu read with K-tag 7.020(red pcb).BDM100 want read that type ecu,inside MPC562.K-tag_OK
209. MB (w211) E 320cdi, read like EDC16C2/3/4 with MPPS and used MB EDC16C31 GENERIC ALL solution EGR-OFF works OK!!
210. Nissan 2.5DCI_2008y_EDC16CP36_(same like Renault Master)_FG_RW via OBD2 CAN_nothing disconnected_EGR-DPF_OK_(cuby)
211. Hyunday tucson 2006 2.0crdi edc16c39 read bdm by Ktag dpf off ok
212. A6_3.0_V6_224HP_2005y_EDC16CP34_FGV54_RW_OBD_SWIRL _OFF_PERFECT !!! Eliminated: P3135, P1018, P3198, P1545_OK (cuby)
213. Ford S Max Galaxy 2.0 TDCI SID 206 DPF OFF + EGR OFF------- OK
214. Ford Focus 1.8 TDCI Sid202 EGR OFF-------OK
215. Opel Antara 2.0 cdti 2008_edc16 r/w Galleto_Software Number: 96950947 P465_V66_DPF ok ......... disconect all sensors
216. Renault fluence DCM3.4 -dpf off after 700km fault P2002,car drve ok but fault and engine light on
217. Toyota Auris 1.4d (1NDTV) 2009 DPF-OFF = OK!!!_R/W KessV2 using EDC17 Toyota protocol @Tricore
218. kia ceed edc16c39 dfp ok
219. VW Grafter 2010/100kw/CECA/EDC17CP20/ Dpf, EGR, Adblue off= OK.
220. Opel Astra/2007/1,9/88kw/Z19DT/EDC16C39/ DPF off= OK
221. mercedes a169 180cdi 109cv egr off ok 2017/05
222. IVECO_Daily_2.3JTD_2012y_EDC17CP49_0281017455_5131 12_KTAG_boot_mode_R/W_OK(cuby)
223. ford mondeo mk3 delphi2.0tdci 131cp citi?i har?i onli nu mpc (dcm3.2 micro mpc) egr off = ok, dpf off = ok ,read by Ktag
224. Land rover defender egr off ok visteon 102
225. VOLVO_V50_2006_D4204T_5WS40212G-T=SID803_R/W FGv54 on bench_in MPC file_DPF_OFF_OK(cuby)
226. Audi A4 3.0L _2006 DPF-OF_OK
227. Ford Focus 1.6L CDTI _2009 DPF_OF - OK
228. Doblo_Cargo(223)_1.3MJTD_MJD6F3HW03_2009y_R/W via OBD_mpps v18_DPFoff_generic_OK(cuby)
229. Suzuki Grand Vitara EDC16C3 dpf and egr off is ok, read-write kess 2.23
230. Opel with PSG16 egr off_OK_R/W by mpps v18 directly on the pump trough connector
231. volvo s40 edc16c34 EGR OFF_OK_It is working,just need cut fault P4438 and plug must be on on conector
232. Renault_Traffic_150DCI_2.5_DCI_EDC16CP36_FGtech v54_via OBD_EGR+DPF_OK_do not forget to R/W injection table!!!(cuby)
233. Nissan Qashqai 2010/1461cm/81kw/K9K/type:J10/Sid305/ DPF off= OK. Made for KESS under Renault Laguna Sid 305.
234. Audi A6/2006/2,0/103kw/BRE/EDC16U31 DPF off=OK.
235. Peugeot Partner 2010/66kw/EDC16C34/ EGR off= OK.
236. Audi A4/2006/2,0/103kw/BPW/EDC16U31/ DPF off= OK. Some errors must be deleted by MTX remover.
237. Nissan cabstar 2.5 ecu denso d3 Read ktag 7.020,egr off ok
238. mazda3 1,6 tdi 66kw edc16c3 egr off with disconect plug all is ok
239. Nissan Patfinder/2011/3,0/170kw/EDC16CP42/EGR off=OK_Do it: KTag Navara under the protocol.
240. A6_2.0TDI_PD_4F_EDC16U31_03G906016MF_391830_103KW_ FGv54 via OBD2(Kline)_DPF_off_OK!!! (cuby)
241. Citroen_Jumpy_2.0_2012y_85KW_DCM3.5_Kessv5.017 via OBD2_dpf off_OK(cuby)
242. P207_1.6_EDC16C34_2008y_sw386119_Kessv5.017 via OBD2_DPF_OK!! (cuby)
243. Alfa_156_1.9JTD_16V_EDC16C8_sw369134_MPPSv18 R/W via OBD2_egr off_OK!!!(cuby)
244. Megan 2_1.9DCI_EDC16C3_Kessv5.07_via OBD_R/W+inj.code list_DPF_off_type1_sw381503_OK(cuby)
245. Tiguan 2.0 tdi 2006 year edc16u1 flap off ok
246. Skoda_Octavia_A5_2006y_2.0_EDC16U34_sw379738_mppsv 18 via OBD_R/W_EGR_off_OK(cuby)
2017 Version NOT OK :
1. Ford Focus Visteon 131 EGR Off doesn't work
2. mj6jf fiat panda remove dpf not work
3. Fiat Marreli MJ8 DPF OFF and EGR
4. BMW EDC17C40
5. OPEL EDC17C18
6. Land Rover Freelander 2 2.2D edc16+
7. Mazda 6 Version_#01 SW#G40LRF7KT3LA) "denso" that's no good
8. ford transit visteon dcu 1 or 2 does'n work
9. peugeot sid 807 fap off not working = not ok
10. Opel Astra J 1,7cdti DENSO DEC, read/write IOTERMINAL, DPFoff = NOT OK!
11. Opel Zafira B read/write CMD1255, EDC16C39, EGRoff = NOT OK!!!
12. Opel Zafira B read/write CMD1255, EDC16C9 EGRoff = NOT OK!!!
13. Fiat Punto ME7.3H4 ADS LAMBDA It does not work the car does not start
14. Marcedes classe C 220 Version 203 not Work Egr
15. vw golf mk6 2.0TSI 270hp R MED9.1 lambda off not work
16. EDC17C64 Skoda Octavia 2.0l 140 PS DPF/EGR Not Working.. .caused error "Control unit for transmission software incompatible" (Because you not disconnected all cable mate) !!!
17. Audi A6 edc16 3.0 2007 DPF not ok
18. BMW E60 edc16 c31 DPF not ok
19. Not work solution PSA SID803 MPC DPF & EGR!
20. Dtc delete not works on vag edc16cp
21. Renault senic EDC16C3 DPF off NOK
22. peugeot 308 1.6hd edc17c10 adblue not ok
23. passat cc 2.0cr dsg edc17c46 dpf not ok fault press clutc pedal (this not dsg)
24. Renault Laguna 3 1.dci sid305 - egr not work
25. 407 1.6 edc16c34 egr off not ok !
26. Audi 2.0 TDI EDC16U31 / 34 EGR off does not work, error P0407 (You must with DCT Remover remove the error)
27. VW Passat BMP engine edc16u34 software switch off dpf and Lambda switches but also deleting not belonging to DPF DTC's like p0490 and P0230.
28. Land Rover SID204 EGR off not work but work in new version 2017.06-1
29. hyundai I40 edc17c08 version 2016 - not working
30. Passat CC EGR OFF not working - car self rew up on low idle
31. Passat edc17cp14 blue montion DPF OFF not work good,regeneration ON
32. Edc16U1 VAG egr off not ok, the same thing with VAG Siemens ppd 1.x
33. mitsubishi pajero 2008 dpf not ok
34. Egr off “EDC16U34 generic solution” on audi 2.0l TDI 140 NOT OK.
35. Iveco new daily 2011 edc16c39 bosch 02810121193 EGR does not work DPF does not work.
36. mazda 3 2007 1.6d edc16c34 dpf solution dosn work….after 170kmh engine try stopAngry
37. Passat ppd 1.2 2007 year dpf ok but cruise control stop working.Please any solution ?
38. tested DPF remove on FIAT EDC15C2 with Citroen Dpf remove solution : not ok
39. FIAT EDC15C2 solution is not available on the soft.
40. Verified on 4,2 q7 edc17cp24. Doesn’t work. Ecu stops responding. After checksums counting ecu doesn’t work anyway.
41. egr off edc16c34 berlingo tepee . first version ,version 1 & 2 all not work
42. Kia edc15c7 egr wrong solution
43. for Hyundai/KIA EDC16C39 DPF OFF wrong solution
44. DPF Remover for Insignia EDC17c19 no good
45. S320cdi edc16 not work., S420 cdi V8 not work.
46. W204 CRD3 not work .
47. Volkswagen Passat cc edc17c46…egr off OK DPF off. No Ok
48. Vw Crafter Edc16CP34 and Opel Insignia Edc17 Not working.
49. C4 PICASSO 2008 EDC16C34 not working
50. Peugeot 807 EDC15C2 DPF Off= wrong solution P1429 failure.
51. Opel Vivaro 2.5tdi edc16c36 dpf+egr off have appeared P0487 P0488 errors
52. opel astar h edc16cp39 1,9 diesel from 2007 egr off not works.
53. Mercedes Delphi 3.5 DPF not OK.
54. Mini EDC16C35 Fap & EGR wrong solution
55. MB W203 C220 EDC16C2 DPF Version 2 ECU bricked
56. bmw edc17cp41 dpf off not ok
57. Renault edc16c36 dpf off not ok
58. VW Sharan 2.0tdi EDC16U31, EGR Not OK
59. VW Crafter EDC16C34, DPF Not OK, EGR, OK.
60. Opel Zafira 2009, A17DTR Denso Dec, R/W IOterminal == DPF not OK
61. Opel Insignia A20DTH EDC17C19, R/W MPPS v18. == DPF not OK
62. Audi a6 2006 3.0tdi edc16cp34 read by obd cant find dpf map not ok
63. VAG EDC17C46 problems with DPF OFF_1.6TDI PCR 2.1 EGR OFF newer sw, the egr is off but also the fuel pump is off, the car will not start because there is no fuel to supply the the cr pump.
64. Renault Traffic 2007. EDC16CP33 R\W MPPS v.18 EGR off - NOT GOOD. Only DTC off, with disconnected EGR connector not work.
65. Kia karens edc16c39 dtc off no ok
66. Skoda tdi edc15p egr off no ok(no value change)
67. audi a3 edc16u1 egr-not ok
68. marelli 6f3_DPF_no work
69. marelli 8f2 fiat 500, panda, y etc..._DPF_no work
70. marelli 8f3 all veichles_DPF_no work
71. bosch edc16c39 euro 5 for all veichles fiat group_DPF_no work
72. Porsche Cayenne S 4.5 V8 Bosch ME7.1.1 HW: 0261207696 SW: 1037371186 100% Porsche Cayenne 100% does not work
73. Volvo S40 1.6D EDC16c34 EGR OFF not ok- Plug connect shows falut P4438 -egr stock close when delete fault in DTC than ok.
Plug must be connect because if it is disconnect shows on dasch Anti Skid Service Requied
74. Fiat Ducato 3.0J TD EDC16C39 DPF off not good
75. mercedes a200 cdi w169 edc16c31 109 cv does not work. the ecu does not command the turbine.
76. edc16 sprinter 3 l biturbo egr off and dpf don’t work
77. Dpf edc15c2 peugeot 406 coupe don't work
78. seat leon 2013 2.0 tdi edc17c46 egr off not ok
79. mercedes a160 edc16c31 dpf not ok
80. Opel Astra j denso dpf off, no ok
81. I made DPF-off on megane 1.5 year 2009 with SID305, no light on but sometimes in acceleration there are power cuts around 2500 rpm, especially with 3rd and 4th gear. Professional DPF Remover V2017.10.2, read write Kess 2.23 OBD
82. Nissan NV200, 1.5dci, ECU SID305 NOT OK. STill generate DTC, limp mode, and MIL on.
83.
ARGOUS
iaw4 v1.2 you have?
Юрий75
Двно имеется программа, но ниразу не воспользовался
auriuxs
Thanks, I've been searching for this for a while now
Achif
пользуюсь активно ,есть конечно косячки но решаемо
